enable neighbor-discovery refresh
enable neighbor-discovery {vr vr_name} refresh
Description
Enables the IPv6 neighbor cache to refresh each entry before the timeout period expires.
Syntax Description
vr_name Specifies a VR or VRF.
Default
Enabled.
Usage Guidelines
None.
The following example enables the refresh of neighbor discovery cache entries:
This command was first available in ExtremeXOS 12.4.
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
